GX390 Balance shaft?
DeathStarr89
Loose Nut
Davenport, Iowa
So to make a long story short, my 390 started making some racket after a few hours of use. I found a small chewed up piece of metal floating in the crank case. I'm assuming it's a piece of the governor that I accidentally dropped when I removed it.
Needless to say, I did find some internal damage however it's only to the gear on the balance shaft and corresponding gear on the crank. The cam gears are fine.
Does anyone have personal experience with running a GX390 w/o a balance shaft?
Thanks
DeathStarr89
Loose Nut
Davenport, Iowa
Here are the pics..
(since everyone likes carnage)
anderkart
Surprise Arizona USA
You'll find some good info about this subject in the honda section of the bobs4cycle.com forums.
After registering, you could type "GX390 Balance shaft" into their search window to find the info.
Last time i researched this (at that forum) I found several guys reporting their GX390 race engines worked out just fine with the balance shaft assembly removed, but there were also a few guys claiming they ended up with severe vibration issues. Seems like one of the more knowledgeable racekart engine builders on that forum stated your results will depend on whether you GX390 is an older or newer production model.
TKart
Ive ran the several gx270s without the balance shaft for several thousand hours with no ill effects as of yet. Just make sure that both crank bearings are in really good shape and you should not see any vibration issues.
TKart
Some of the gx model engines do not have a balancer shaft and the crank does not have the gear to drive one either. Its weird because the provision is there for the balance shaft bearing but the bearing does not fit. I tried to press it in once...everything was true and straight...cracked the case. I havent bothered with adding one to a non equipped one since.
The boss may have been cast into the cover, but likely wasnt machined. Simply casting the boss isnt enough, they would have used a fixture to perfectly align the machine work.
