DeathStarr89
Loose Nut
So to make a long story short, my 390 started making some racket after a few hours of use. I found a small chewed up piece of metal floating in the crank case. I'm assuming it's a piece of the governor that I accidentally dropped when I removed it.
Needless to say, I did find some internal damage however it's only to the gear on the balance shaft and corresponding gear on the crank. The cam gears are fine.
Does anyone have personal experience with running a GX390 w/o a balance shaft?
Thanks
Thanks
