gx270 not starting PLEASE HELP
rhys_wir
calgary canada
hello everyone,
i have a brand new gx 270, i had run threw a whole tank of gas and ran out, i have refiled it and nothing, the gas is good,
i have
-checked plug - was kind of fouled, cleaned well with file, tested grounded on frame, was a spark,
-cleaned carb - no dirt, perfect
- checked compression - perfect
- checked valves and timing - good
- engine started after 10 seconds on electric start, was very weak and died.
when it has ran out of gas i had rocked it on its side to try and get the gas to move. than after refilling didn't work. also the day it ran out of gas i was stupid and left the choke on. Everything looks good in it. only thing is oil cut? but it is full, could it be because i tilted the engine. is there a way to disable it to test.
thanks - RW:thumbsup:
rocketkart
florida
there is a wire that gose into the block. disconnect it and see what happens. also try i new spark plug. also make shore you are geting gas to the carb.
rocketkart
florida
its properly the spark plug cus you sed you had spark when you grounded it to the frame. but idk it can be somethin else.
KartFab
Dallas, TX
if the problem is your spark plug you can put a small spoonful of gas in the spark plug hole, replace and pull the cord with the choke off and throttle wide open. After the first or a couple pulls, it should start and run for a few seconds. If it doesnt start, you have a spark-plug/ground/coil gap whatever related problem
If the engine starts and runs, then dies its a fuel problem. (Its almost always a fuel/fuel delivery problem btw).
the reason why I dont think it is your spark plug is because you already tested it and its a brand new engine.
i have
Its gotta be something dumb/easy like you ran the fuel out of it, and the jet is blocked, or you turned the gas lever to "off" so the bowl doesnt fill with gas, or you have bad gas, or you accidentally switched the kill switch to "off" - happens to a lot of us.
I would have to agree, probably a blocked passage or jet some where. Use one strand of a soft copper wire and check all passages or better yet if you have a air compressor blow them out.
skimf
England UK
try boiling the carb in vinegar? did it for me on my gx160, also i dunno wether youve tried it on half choke?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I would also say When you ran out of gas some crap out of the bottom of the tank got into the carb, and you need to clean the carb not chase after spark issues,
Try Kart fabs method sounds like it will pin point... gas or spark.
