Gx240 Crank on Gx200 engine?
Wakein777
First time poster here, but was wondering if the gx 240 crank would fit in the gx 200, and hopefully increase the stroke length. Would it also fit in a predator 212?
B.M.800
TheBeal.
Central PA
^^ I take it the piston cant be shortened?
Ive had the head off a clone, but havnt had the guts out Im not sure what it looks like in there.
Jrgunn5150
Rudderless
Ordinarily, one of two ways. The ideal way, is find a piston with the correct diameter, but a pin 4mm lower, so it goes down further into the cylinder, not up higher.
The other way is a stroker plate, which sits between the cylinder and head and effectively makes the cylinder longer.
I have no idea if either is an option in this case.
I'm gonna go out on a limb here & say absolutely not! The GX200 is a "small block" whereas the GX240 is a "big block"; that would be like using a 350 chev crank in a 454...
Jrgunn5150
Rudderless
Oh, well then lol, that would get you into grinding and all sorts of nonsense that probably fall into the "not worth the effort" category.
