GX240/270 Billet Flywheel
pantsman
Hi all,
I'm slowly building up an old gx240 i salvaged from the local dump/tip. Its now time for a billet flywheel, however I can't find one with electric start ring gear that's made for the gx240.
I really, REALLY want to keep the electric start so I've been wondering if the 390 flywheel will work? so long as the shaft size and OD of the 390 is the same I can't see why it wouldn't? Have a missed something here?
Cheers,
anderkart
Surprise Arizona USA
Did you already ask ARC racing if they'll interchange? --> http://www.arcracing.com/honda-clone/
Or If not, ask If their 390 ring gear will bolt right on their 240/270 flywheel?
And If not, ask if they could drill/tap it so it would...
PS: You might be the first person that's ever requested this configuration, so I'd suggest you do a tooth count and outer-diameter measurement of your old ring gear, and have that info all ready to tell them when calling/emailing.
ARC will probably also want to know if you want to retain your charging system or not... :thumbsup:
pantsman
Cheers for the speedy replies guys,
I have emailed ARC and Dyno about the possible combinations, but neither have replied yet and its been 3-4 days.
I know I'm a bit weird using the 240, but it was free and is the perfect size for my little roots blower.
I have all the tools I need to tap threads into a 240/270 flywheel to add the starter gear, so thats an option if there is enough meat left on the underside of them.
Failing all that, i guess I'll just go straight to my end-goal of digital ignition + EFI and machine my own flywheel.
