r_chez_08
Should be in the shop...
Hi,
Quick question- I was planning to do some welding on my kart and wanted to turn it on its side and upside down. I don't really want to remove the engine. I have already drained the oil because I was going to change it. I have run the motor with the petcock shut till the engine died and the carb was empty. I was going to drain the gas tank to stop petrol leaking from the cap "air gap" (the little gap to stop a vaccuum in the tank).
Will the motor now be ok to be turned upside down? (not running of course!)
I did the same with my mini bike except left oil in and the motor smoked for a bit so I figured I would drain the oil.
If it wont be good for the engine, why? Just wanted to check
Cheers
Rob
Cheers
Rob
