I visit Bob's 4 Cycle Forum & that question comes up frequently for the Predator engines. Most people have to experiment by reading the spark plug after enlarging the jet size in .002/.003 increments. If the motor requires the choke to be partially closed to run at speed then the jet size needs to be increased.
Note: drilling the jet without polishing the hole will reduce flow thru the jet. Find a small toothpick & some valve grinding compound and work the toothpick into the hole to remove burrs & swirl marks from the drill bit.
