Gx200 clone kicking / hiccup?
iCloud
Hi first post and as always not to sure if this is the right place but I've had an idea for a go kart of my own for a while so I bought a gx200 clone with a faulty carb of ebay.... That's how it started or didn't start in my case so I'll cut to the chase I've replaced almost everything part from the internals which are all fine, gaskets, coil, plug and carb all these things have made it slightly better and it runs and revs but it's got his hiccup of sorts at idle it's like almost kicking the engine over and at full revs it's like a hiccup where it stutters for a fraction of a second and I cannot find out what it is can anyone shed some light on this before I pay £120 for a rebuild? It's not the carb as I've replaced it and the lines and drained the tank done valve lash etc etc all the filters any help is appreciated
Poboy kartman
Senior Moments Member
White Settlement Texas
Seat of the pants guess....bad coil wire...(possibly the insulation on the small one)....at any rate...what you describe is an electrical issue.....
Welcome to the forum!
EDIT: I just noticed you replaced the coil.....carefully inspect those small wires....wiggle them to check for breaks....especially right at the terminal ends...
Poboy kartman
Again....just a guess...but, eliminating electrical, there's only one other thing that comes to mind: a valve that is sticking for some reason, possibly bent, but doesn't return to closed occasionally....probably the exhaust valve, which causes the intake charge to explode before it's time...if so, there should be a backflow of pressure through the carb....
So try starting it without the air filter and see if you feel some air coming out of the carb when it coughs.
iCloud
I took the valves out and they could use lapping but I'll try that now !
iCloud
I had the head compleatly apart and replaced the springs and it's still doing it, I checked the valves and sealing surfaces and they are all good the top of the cylinder head is black though even after I cleaned it but the piston is clean on top, the new plug is very black which I think means it's running to rich but if I start the engine with the fuel stop barely open it runs smoother with only the occasionally kick but if I fully open the fuel its a lot more frequent and violent and is a lot more prone to stalling and the governor is still intact and installed it's had new throttle and governer springs installed on top and the throttle is set properly and the carb fully closes and fully opens smoothly and the governer arm does not look like its surging anymore after I replaced the springs as the engine holds an rpm and then just like what I assume it misfires or kicks the engine ? Is there a way to adjust the air to fuel ratio? I replaced the carb with a new gx200 carb, I've tried disconnecting the sensors and it still does it so I have no idea what it could be I would think advance timing key but I don't want to cause any more damage by advancing the timing
iCloud
I couldn't or didn't want to remove the flywheel as I don't have a torque wrench and I only have a ratchet big enough and I don't want to break it but the guy I bought it if said it has a new one anyway so I wasn't to worried
Depending on the severity, a rich condition can cause an engine to stutter & stall due to flooding; try switching to a smaller main jet...
iCloud
That sounds familiar as the plug is black and if I put the fuel about 2mm switched on it runs just fine at idle and about 1800 rpms then just fuel starves
