Brad_R
Hey guys, long time no see?
Anyway, got a new engine, picked it up from a second hand shop for £40. It's a GX200 clone and it runs. I havn't done much to it apart from change the plug (To a BPR6ES), change the oil to RockOil 4 Stroke Oil (I think its SAE 30, got it for £3 so it will do for now!) and give a minor clean.
I was thinking about making a minibike and using it, but using it on my soon-to-be-scrap-metal gokart for the last time (It's far too small for me now, I'm 16 and it was built when I was turning 14)
The problem is, It needs around 1 minute to warm up before it will accept any revs without dying. It will not start without half or full choke - which is understandable - and can be instantly switched to no choke when it's started. I am in need of some information on how to fine-tune the mixture as I cannot find information on this. (This is my first serious working Honda, check my previous posts to find out the problems with my GX340, if you want
Here's what I am thinking:
Changing the emulsion tube to a GX140 E-Tube and rejetting if its needed. However, I have no idea about the jetting or emulsion tubes. I had to ask GranPann on Youtube (Forgot his DIYGK username, thanks anyway though!).
Heres where I'm stumbling a bit. I would have no idea of knowing what sized jet to use and even what effect it would have to the engine. I gathered it will make it run richer.
I'm hoping you smart people of the forum could help
Cheers,
Brad
Cheers,
Brad
