Jmart432
Hi everyone. I picked myself up a Honda gx160 from a garage sale yesterday and I'm trying to get it running well before I start the go kart.
The problem I'm having is to do with the carburetor. It has a fuel on and off switch which I just have on all the time which is fine and a choke that works fine but theres no throttle control other than that arm off the governor. When I start the engine I have to have that armed turned up a bit or it won't start but then it revs heaps. If I turn that arm back down the engine will die and I can sort of find a balance where it can idle but it stills seems to high.
Is that what most people use for their throttle? Just a cable hooked up to the Governor? Or should I try and take the governor out and try and make up some other throttle assembly??
Thanks for any help
Thanks for any help
