gx160 new carb problems
abelmanuel94
Ok so how are you guys doing im from florida i have a gx160 or Honda 5.5 that i got a new carb for it on ebay it looks close to what i got almost the same and i put it on its new and it turns the engine on choke and only runs on choke i dont know why i also dont know in was conditions the engine was runing befor that what could it be
KartFab
Dallas, TX
Did you clean out your gas tank, union (filter between the tank and fuel line) and fuel line itself? Is the fuel line cracked and old? If so, you may need to replace the fuel line.
Only running on choke means it's not getting enough fuel. Why it's not getting enough fuel is unknown. Usually it's a clogged jet issue.
abelmanuel94
Ok this engine is old got it off a compressor my dad had the carb what realy bad to i buy a new one and new gas line and filter the tank is old and smelled lik realy old gas but i clean it out and put new gas line and filter the only thing i can think is that it needs a bigger jet hole or this carb had a pilot scrow that the othere car dosnt have
---------- Post added at 10:23 PM ---------- Previous post was at 10:20 PM ----------
I think its the jet that needs to be bigger the engine is old i got it off a not runing compressor and i put the new carb from ebay and new gas line and filter and clean out the tank now the only thing i can think is that the new carb has a pilot jet i think its called and the old one looks like its pluged
First, :welcome2:
Second, :useless:
Even if the main jet was too small, it would still run off choke, it would just run lean...
There is either a blockage somewhere or a gasket/spacer is either broken or fitted incorrectly...
abelmanuel94
i dont know if you guys can see the pics but one is the original and one is the aftermarket carb if you look at both pics you will see under the black screw you will see the original honda has a black cap and the other one has like a jet
---------- Post added at 11:45 AM ---------- Previous post was at 11:44 AM ----------
https://www.google.com/url?sa=i&rct...k28cK2cmJjxe2GRwKSmyXNzA&ust=1442597678511874
---------- Post added at 11:46 AM ---------- Previous post was at 11:45 AM ----------
---------- Post added at 11:46 AM ---------- Previous post was at 11:46 AM ----------
i dont kno is thats what making the engine not to be able to run with out the choke
abelmanuel94
thank i got it runiing good now dose anyone know what size bolt dose it take to hold the clutch the bolt that gose in the shaft
