GX160 issue again
r_chez_08
Should be in the shop...
Cornwall, UK
Riding my minibike today, and it was low on fuel causing a lean condition. Rode it on partial choke to the house, then it died.
Topped up the fuel and now the engine will refuse to start. Occasionally it fires and chucks a puff of smoke out of the intake.
Does this sound like the flywheel key has sheared, or maybe another issue?
Cheers
Rob
Edit- the bike started and ran for a few minutes, and then stopped again. I will try a new spark plug as it seemed to be misfiring before it died. It also pisses fuel out of the carb (probably a stuck needle or bad seal) so I will fix that too.
kendelrk
redneck engineer
westland michigan
is it still pissing gas? might not be able to get any through the carb to get the engine to run, if not make sure the fuel line is flowing.if not make sure that the fuel on/off switch hasent locked up. on an old clone i had it got stuck closed. so you have to take the two philips head screws out, dont loose the spacer and then pull the little rubber gasket out and switch it to the next hole. also do you have the gas line where it is from factory? if not it might cause a gravity feed issue and not be getting any fuel. i dont think you would shear a flywheel key or anything from doing that. the carb is probablly just dry
r97
Measure twice cut once
Massachusetts, USA
What kind of fuel filtration does the engine have? If you ran it out of gas it could have sucked up some sediment from the bottom of the tank. That could partially clog the fuel line (would only run for a few seconds, then not start again until a few seconds later). Sediment in the fuel system could also explain a needle not sealing. Do as blaz says too, IIRC white smoke coming from carb is a sign of a fouled/fouling plug.
r_chez_08
Cornwall, UK
Ok, I am away for a week but will look at the plug/ carb when I get home.
I thought it was probably the plug.
There is gas getting to the carb, the carb is leaking somewhere. Either from the plastic insulator or from the bowl, can't tell.
Maybe a stuck needle, hence why I had gas in the oil.
The filtration system is stock, with a small filter in the tank and a sediment bowl on the carb. Stock replacement clone fuel pipe. No inline filter, can't find anywhere to squeeze one in on these motors! Maybe a small one would fit.
FatCat
2 stroke Addict!
Ottawa, IL
You can clean most any fuel filter quite easily. Will save you time and a few bucks. Spray carb cleaner through the fuel filter (backwards) the opposite way than the fuel flows. Just spray it till it's completely clear and you've got an as new filter. If you see any damage to the filter media you'll want to replace even if it looks clean. A filter should last many years unless your feeding it a lot of crap. I hate fuel issues since they are usually preventable. I bought an assortment of funnels at the local hardware store that have screen filters in the bottom. You would be amazed at some of the **** that I've seen them catch. Feels good knowing your not feeding that stuff to your engine. That's straight abuse in my eyes. I use these for fueling all my toys. I highly recommend these for just a few bucks.
