Gx160 help with idle
r_chez_08
Should be in the shop...
Cornwall, UK
Hi,
Got a small problem with my gx160 after installing a gx200 carb and thinner head gasket-
Seems to run fine in the higher revs (2500+) except for some governor spring trouble (I think I will just rip it out)
However, at low rpm, the idle hunts around, and only runs partially choked. I tried fiddling with the brass idle mixture screw, but no joy. Could it be an over lean idle jet, or maybe the compression release on the cam playing up? I can try the original carb again if need be.
I think I am going to just rip out the governor, and make a linkage directly to the carb. Then tune the carb to run correctly. Sound like a plan, or should I try something else?
I want to rip out the governor because the spring has been over stretched and it doesn't function correctly.
Thanks
Rob
r97
Measure twice cut once
Massachusetts, USA
I would rip the governor and tune from there. No point in getting it running perfect just to find removing the governor makes it run like crap again.
Good luck!
r_chez_08
Cornwall, UK
Thanks. Nice to have another opinion.
I Should probably regear after doing the governor. I sh!t myself going any speed on a mini bike :p
Anyone got some good throttle ideas using stock parts?
Edit: found some ideas.
r_chez_08
Cornwall, UK
Pretty sure! I will check though.
I think I stripped some threads to mount the blower housing, what is the best way to repair these? Helicoils? Or just tap one size bigger and use larger bolts.
