Gx160 clutch problems
Ctchme
Hey guys, I'm new here, am having some trouble with my max torque clutch on my go kart, the cover (part that the chain goes on) keeps falling off above 3000 rpm. Any idea on what I can do to fix it?
GregMartin
I like fast cars
Brisbane Australia
I don't understand. The circlip on the outside holds the drum and sprocket on the clutch internals. So if it's in place correctly the drum cannot drift off. Do you mean that the whole clutch assembly is drifting of the shaft? If so there are two things that will hold it in place. The first one has already been suggested by Landuse, that is there should be a bolt and washer threaded into the threaded hole in the end of your engines drive shaft. It should be tight, I would use Locktite. Secondly the shaft should have a keyway and the clutch should have a couple of grub screws one of which is in alignment with the keyway. These grub screws should also be tight.
Ctchme
Well took the engine off today, and there is no bolt in the shaft, does anyone have a picture of it bolted in? For reference? And what size bolt do I need in it?
GregMartin
I like fast cars
Brisbane Australia
Normally it is a 5/16" x 24 tpi Bolt for Briggs and Honda engines. The washer should be a slightly large diameter than the engine shaft. The centre hole should be a clearance hole for a 5/16" bolt.
This is a picture of a Briggs with a clutch fitted the bolt is removed and you can see the threaded hole in the end of the shaft.
My Oh Five
www.diygokarts.com/vb/showthread.php?t=18728
Ctchme
Thanks for the info guys, ended up finding a bolt that fit in the end of the shaft,now it won't fall off
