Gx flywheel plea for help!
r_chez_08
Should be in the shop...
Cornwall, UK
Hi,
I have been searching everywhere for a used cast aluminium Honda flywheel for my clone build. The cast aluminium flywheels are from a gxv160.
A member on OMB tells me he has some gxv120/140 ones, however he says they will not work.
I have access to a lathe so I can retaper and re cut keyways.
Does anyone know the difference between a gx(v)120/140 flywheel and a gx160/200 one? It can be the difference with the iron ones, they are practically the same dimensions.
Thanks!
r_chez_08
Cornwall, UK
Thanks landuse. They seem pretty much the same. I just need some dimensions now. I think as long as they use the same magnet I should be able to get it working.
