GX 340 engine help needed
grampy 1
I'm lost on small engines.This engine is smoking & some oil drips from exhaust.I realize this is bad & could be rings,pistons or other internal parts. Is there anything simple that could cause this? What can i check first? It hasn't been used alot and was running good till this started. It will start.
anderkart
Surprise Arizona USA
I agree with landuse's post.
A couple more simple causes could have been:
That the fuel shut-off valve was left on, and you now have crankcase full of gas.
Or, that the engine/kart was stored at an extreme angle, which would cause the (the correct amount of) engine oil to migrate to where it shouldn't be.
If you take off the oil plug, and there is gas in the crankcase, make sure your eyes are well away from the port. Last time I had gas in the base, it flung the oil cap a ways away from my hand a a littler fountain of oil/gas was spilling all over the place.
grampy 1
I appreciate all your quick responces. I'll check them all tomorrow & let you know my findings.
