mark123
I have a Honda GX 270 which will run but is very hard to start. It consumes a lot of oil and only has 50 PSI compression. There are approx 10 000 hours on it so I decided I would replace the rings and head gasket. I opened it today and the head gasket looks OK, I took the top ring off and placed it in the cylinder approx 1" down and it only has 0.021" end gap, does this mean the ring is not worn very much. There is a tiny bit of scuffing between the piston skirt and deep down in the cylinder but this area is not where the rings touch. Another thing I noticed was that the top 2 rings's gap where aligned, I assume they should be opposite each other, but thre is no pin to stop them from rotating, should there be? What else can I check that would caue poor compression and oil consumption? It always had 100 synthetic oil in it and changed frequently.
