GX 200 Lacking RPM
aksleder
I bought a modified gx 200 from NR Racing last year and installed it in a zr 200 snowmobile. Engine has 280 Cam, 27/24 valves, 26lb srings and 10.7-1 head. Governor has been removed.
When I first got it the engine ran great and had tons of power, but then the carb broke (22 mikuni round) from hitting the frame. So I went with a new set up and installed a 26mm pwk. Jetted it to chocolate brown but the engine still wont rev past 3400-3700 rpm. I'm stuck and not sure what to check next.
Could the valves or springs have gone bad or could it be something electrical? Any help would be great.
Flyinhillbilly
The great cornholio
North West Arkansas
If it was running good until the carb broke I’d suspect a carb problem. I’d drop a few sizes on the main jet and see what happened. Will the jets from the old carb fit the new one?
aksleder
No it’s a different style carb and I already tried different jets, both leaner and richer.
aksleder
It has billet rocker arms i don’t think it has billet connecting rod, I don’t believe it’s a carb problem. I put all new intake manifold, gasket air filter and the carb
As I understand it...With out that billet con rod... its going to be a block problem... as in a hole in it as something lets go, with that setup...
thedude306
sled guy
Canada
Does that sled have a rev limiter? I know the polaris 120 throttle flippers do. Messes up the signal from the coil. They even have a statement on unplugging it for an "emergency" to get the sled home in case of a failure. Unplug everything and manually ground the coil to shut off. See if problem goes away.
Oh and pictures just cuz I'm a sled guy.
