guide to taking off and replacing starter clutches
kendelrk
redneck engineer
westland michigan
Starter clutches
Starter clutches are a meaningful piece to your engine, they make sure when you pull the recoil it turns the engine over, but that it also rewinds the recoil.
Starter clutch problems
So you’ve noticed a screeching in your recoil when the engine is running, and also the recoil not retracting, getting stuck halfway through a pull or not catching, this can sometimes be your recoil, so check that first but your starter clutch could be bad.
You’ve diagnosed it’s the starter clutch
Now you’re needing to fix it, I would recommend and it is recommended that you replace the starter clutch its about 25 dollars at a local lawn and garden shop.
Removing starter clutches
An easy way to remove the starter clutch is to dump a cap full of a solution called CLR onto the seal behind it, and let that sit for 5 minutes, then have a helper hold the flywheel and put a screwdriver to the notches on the outside, and smack it with a hammer multiple times, soon enough you should be able to spin it off by hand,
Putting on the new starter clutch
First clean the shaft with emery cloth, add a bit of 10w-30 and then wipe it off, you want the shaft clean and with no dust or dirt, then spin on your new starter clutch, again have your helper hold the flywheel, and put a rag over that some notch you hit on the old one and hit in the opposite direction, the cloth helps to not hurt them, then replace your recoil housing and your finished, you’ve changed your starter clutch and your engine shouldn’t give you any problems with your recoil not catching or getting stuck
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
What engine is this for? Briggs? Theres no need to replace the clutch, all it needs is a little lube. I already did a right-up of this anyway.
Its from a lack of lubrication. i just did this about 2 weeks ago. You'll need to take the recoil cover off to get to the starter clutch. It looks like this:
Use a flathead screwdriver to pop off the seal/ring around the shaft. There are 6 steel balls behind this seal. They may fall out when you get the seal off, so make sure to keep your hand under it to catch them. Get all 6 of the balls out and clean them a little. The clutch shaft will come off easily. Take that off and clean it. That squeal is caused by a lack of lubrication between the crankshaft and the clutch, so you need to put some oil on the end of the crankshaft and on the inside of the starter clutch shaft. Put it back together, starting with the clutch shaft. Its a PITA to get those balls to stay in, but its easier if you have the engine leaning back a little. Once you have the balls in the right place (its obvious where they go) put the seal back on. Test it by turning the starter clutch both ways. It should only be able to turn one way. Put everything else back on and your done.
kendelrk
redneck engineer
westland michigan
mine was so far gone it wasnt useable even with lube,, this is for a briggs, the recoil ratchet was off of it, the seal was already half popped off , so i just got another, and when i pulled off the other peice of the seal, it actually had a few cracks in it,
devino246
Lynchburg, VA
Just because you dont change your car's oil and have to replace the engine doesnt mean you should tell everyone else to replace their engines too. Get the analogy?
devino246
Lynchburg, VA
That's what the little hole is for.
Routine maintenance. No need to disassemble.
But whats the fun in that?:roflol:
The hole would be fine if you actually do it as often as your supposed to, but when its to the point of screeching, Id rather make sure it good and lubed.
