kendelrk
redneck engineer
Starter clutches
Starter clutches are a meaningful piece to your engine, they make sure when you pull the recoil it turns the engine over, but that it also rewinds the recoil.
Starter clutch problems
So you’ve noticed a screeching in your recoil when the engine is running, and also the recoil not retracting, getting stuck halfway through a pull or not catching, this can sometimes be your recoil, so check that first but your starter clutch could be bad.
You’ve diagnosed it’s the starter clutch
Now you’re needing to fix it, I would recommend and it is recommended that you replace the starter clutch its about 25 dollars at a local lawn and garden shop.
Removing starter clutches
An easy way to remove the starter clutch is to dump a cap full of a solution called CLR onto the seal behind it, and let that sit for 5 minutes, then have a helper hold the flywheel and put a screwdriver to the notches on the outside, and smack it with a hammer multiple times, soon enough you should be able to spin it off by hand,
Putting on the new starter clutch
First clean the shaft with emery cloth, add a bit of 10w-30 and then wipe it off, you want the shaft clean and with no dust or dirt, then spin on your new starter clutch, again have your helper hold the flywheel, and put a rag over that some notch you hit on the old one and hit in the opposite direction, the cloth helps to not hurt them, then replace your recoil housing and your finished, you’ve changed your starter clutch and your engine shouldn’t give you any problems with your recoil not catching or getting stuck
