GSXR250 won't start
tomas02
Hi,
I have a Suzuki GSXR 250 engine that will not start.
I'm not sure if fuel is getting through carb as motor doesn't even cough or splutter.
It has spark I've checked
Would like to know why fuel isn't getting through.
I don't have airbox on could this make any difference when just trying to start it?
maybe carb is dirty? if so how would i go about cleaning it?
Cheers Tomas
tomas02
You mean put it in a pot with lemon juice and boil it?
Seems very odd haha
Also would there be anything else I can use as that's alot if lemon juice
anderkart
Surprise Arizona USA
I'd start by priming the carbs and see if It'll try to start. Try pouring about a 1/2 ounce of gas into each carbs large air-inlet opening where your air cleaner/box attached.
If it pops and tries to start: Make sure your getting a good flow of fuel to each carb, then post some pics of your carbs and their brand/part numbers.
Your engine should still at least try to start without the airbox installed, although some have small vacuum lines running to them that might need to be temporarily plugged off.
redsox985
PA
Try cleaning the carb and also pouring a teaspoon of gas into the spark plug hole. Sometimes it will have spark outside, but won't be strong enough to light the gas inside the cylinder.
tomas02
OK so I cleaned the jets from the carb in petrol and soaked them for a bit. they are now all clean.
Now in regard to Anderkarts post.
How do i prime the carbs? lol noob question
My carbs are twin Mikuni BSW27
Have attached a exploded view of them from a manual
The lite blue arrow is where I have my fuel line attached. Is this right place?
The dark blue arrow has nothing attached what should be attached here?
Thanks heaps for all the help guys
anderkart
I've never owned anything with CV carbs so I dont much about them. But when you have the float and needle and seat valve removed, the port flowing to the needle and seat valve would have to be your fuel inlet fitting.
So If you took a can of carb cleaner with the little straw on the nozzle, and sprayed into the the carbs body through the seat, (#28 on the diagram below) you should see the carb cleaner exiting where your fuel line would connect.
This diagram below is a different Mikuni model from yours, I just posted it for reference purposes. On this model, I'm pretty sure the fuel line from the gas tank would connect to #11, (the fuel cross-over pipe).
tomas02
Unsure on all of this so I've given up and am just going to take to the local suzuki dealer.
might punch a hole in the wallet but at least they'll know what theyre doing.
Will update you on what happens
Sentrek
Carrollton, TX.
I am having very similiar issue with my GSXR750. I can get it to sputter from starting fluid but can not get it to catch and run for any time at all. I am fixin to tear the carbs down and clean them real good 1 more time.
And #11 is where the fuel line attaches, #14 should be the vacuum line for the fuel petcock and #13 I believe would be the fuel overflow.
kendelrk
redneck engineer
westland michigan
sentrek, heres what you should do first, attack your fuel line and pour fuel down it, have a pot underneath it and see if the fuel is flowing at all, if not, theres a diffrent story, if its running from starting fluid, its most likley a carb problem, with fuel not getting into the carb
bighead
Pacific Northwest USA
I also find boiling in lemon juice to works great.
Just dump a little gas in the plug hole. if it fires then look at your carbs good. Do it a few times if it fires and dies.
