Hello, so I have a Murray Go kart frame (Picture is not mine, just one I found off of the internet. My frame is covered in rust, doesnt have front shocks or a roll bar and is currently in pieces). I also have the engine off of a GSXR 600 bike and I need some help mounting it on. The issue isnt fabricating mounts how ever, I'm concerned about how the back end of the chassis will support the engine since it is only connected to the front via 2 shocks and 2 other bolts. Would I need to add an extra shock in the back (to maintain the suspension)? Or would I have to scrap the suspension and just weld both parts of the frame together. If need be, I can get more detailed pics of the chassis and the engine. Thanks in advance for any responses.
http://i222.photobucket.com/albums/dd128/blk905pt0/Image024.jpg
Basically, what you should do is use the design of a race kart & scale it up to suit the size & power of the engine. This should be an interesting build...
