GSX250 go kart questions
tomas02
Hi
OK so i have a GSX 250 engine 1990 version and it has a 14 tooth front sprocket with #520 pitch
want to know what size rear sprocket i would need so the top speed is about 100km/h
I can't find a max output rpm of the motor which is why I've told you what it is
Thanks
To calculate it out, you need the engine's max rpm, the final transmission ratio. If you can't get this info from a spec sheet somewhere, your next best bet is to grab the bikes original rear sprocket and count the teeth. That's a good starting point. The bikes original ratio would be a bit high, but odds are good that your projects rear tires are smaller, effectively lowering the ratio.
tomas02
forgot about tyres
rear tyres are 16 inch diameter
and unable to find max rpm or final transmission ratio
anyone know where i could find that
also i dont have the original sprocket just have engine
