gs500e engine flooding
i am building a buggy and using a suzuki gs500e engine my problem is i cant get it to run right i know its the fueling i have it gravity fed atm and it will idle if i choke the fuel off quite a bit but i cant give it any throttle or it will die or i can open the fuel up to where it wont idle but it will rev up idk what to do do u guys have any ideas?
52172
whatever jets were in the bike when i got it it ran just fine b4 i took it off thebike
DS13
Annoying the Neighbors!!!
Elysburg, PA
Hmmm I'm not an expert on this type of thing... id wait for toystory to give ya some more advice
carter
If I recall this indicates a lean condition, pretty fairly lean at that. I'm with ander, you're probably gonna want to clean your carbs, blow out the jets and make sure its all cleaned out.
