Greetings From San Jose, Ca
lucasszy
Well after promising the 14 year old that I would build him a gokart, I finally got around to it. Started getting all the parts a few weeks ago, and finally got the steel.
here is the plan to date:
1/2 square tubing - Yes most people recommend going to 1 inch, but I plan to box anything that isnt strong enough for me to sit in, let alone my 90 lb teen. I have 80 feet, so Im not worrying to much.
Got a HB 6.5 HP motor out the door for 80 out the door with an extended warranty for 2 years. SCORE.
Still looking around for all the hardware and odds and ends.
Plan is to make a two seater kart (1 in front of the other, with the second seat passengers legs down the sides of the first passenger)
Cart will be a live axle, on road kart only.
HF wheels.
I plan on making as much of it myself, and only buying what I cant weld, since my metal working capabilities are limited to welding, cutting, grinding. No lathe, etc.
Going to draw out plans this weekend and post some basics plans then!
Cheers
Lucas
anderkart
Surprise Arizona USA
HF wheels.
Welcome to DIY :thumbsup:
Your turning radius will most-likely end up being very wide with a kart that long. Especially when running a live axle on pavement. I'd seriously consider changing your plans to a more conventional side by side seating arrangement and shorter length.
Those H/F wheels suck, lots of guys here on DIY have tried them with lightweight single seat karts and we had several reports of the rims hub breaking off while corning, not a good thing at all....
Gillgamesh64
Griffith NSW Austraila
That sounds cool to me haha you could roll with the whole fighter jet Theme... But if you are not planing to go off-road why not save your self and axle and drive one wheel so you can turn better and save tyres? Anyway welcome to the site, Looking forward to see what you have planed!
Hi there, and welcome to the forum. I look forward to seeing your build! The 1/2" tube thing has me a bit concerned, but with enough bracing- well- anything's possible I guess. Be sure to start a build thread and toss up pics as you go!
lucasszy
Build Thread
Going to start a build thread, as we're already a few days into the build.
After first test fittings, decided to go with side by side seating. The length would have been a killer, as noted. Total frame length is now under 5 feet.
The 1/2 inch tubing is working out great with bracing. Pics and details will be located in a thread, as well as on our weebly site.
http://shizmo.weebly.com/
Check it out, and more pics and details coming soon.
Would have had the frame welded up today, but a cat ripped the mig gas line and I lost my whole tank of gas.
Cheers
Lucas
