Grayhound 13HP seized up
supermanotorious
Winchmaster 5000
New River, AZ
My trusty old winch engine finally seized up on me. We were running the winch. It wasn't running good despite full oil and freshly cleaned carb. It seized on me. I drained and opened the case and see no damage. No broken parts, no sign of metal on metal grinding but I can not turn it over. Any thoughts?
Stuck a ring sounds like.
Pull the head, unbolt the con rod from the crank, spin crank out of the way, tap piston out and start over. Or it seized the crank bearings. You'll find out.
supermanotorious
Winchmaster 5000
New River, AZ
thanks, I need the winch right now so I'm throwing a brand new 420cc Predator on it that I was originally going to put in my Manco. Like a bonehead I forgot about the throttle linkage for the 420cc so I de-governed the engine and got the governor arm removed. Now I'll have to fabricate custom throttle assembly. Oh well. These Predators use a larger diameter rod for the governor so I'll need to get creative with the hole left by the arm, 1/4" self tappers are too skinny
Go outside and find a stick, and some bubble gum. Chew gum till soft and put half of it in the hole. Insert stick about 1/4", and break off the excess. Cover the top with the remainder of gum. Ready set go.
