WB4RT
I want to build a simple mini bike like I had in 1960. I'm saying it's for the grandkids, but I just want to try to build it and expect I'll be the main one to ride it.
I know I can buy a used one cheaper, or even buy the frame cheaper and easier than I can build it, but I'm a fair hand at welding, and well, I just want to do it myself.
I know I should have the main components before I build the frame, but I thought I could go ahead and bend and weld the two side frames, then adjust the width to fit the wheels when I get the kit before i weld the sides together.
i'm thinking I will buy the Azusa 5" or 6" kit without frame so I can get all the hardware in one shipment. Then I will use a HF Predator 212 cc engine.
It seems 7/8" tube is the main choice for the frame. Will that support up to 220#'s?
My questions:
1. Does this sound like a good plan? Other suggestions?
2. Should I buy 5" or 6" wheels?
3. ** MOST IMPORTANT ** - can someone provide a drawing and/or dimensions on the frame? I have searched here and all over the internet without finding what I need. I want to know the length and height of the frame (or at least the minimum length and height to fit the engine). Also the bend radius.
Any help in getting my project started is much appreciated.
Burt
My questions:
Burt
