ty rail kart
- Messages
- 17
- Reaction score
- 0
I have a 6.5 greyhound engine and i took the governor out and now when i turn the choke off it is stuck wide open. any ideas what it could be?
i didnt take any pics while doing it but i physically took the whole gear out of the engine. and the throttle is stuck wide open the only way to slow down the engine is by flipping the choke on then it is at low idle.
is there anyway to stop it from doing that without putting the gear back in?
Attach a throttle cable to little hook on the carburetor that the governor arm went to, then install a return spring.
Sorry I edited my above post. But yeah, that's what I would do.
Or - you can put the entire governor assembly back in, and just attach a throttle cable to the governor arm, so you can bypass the governor without even removing it.
