governor remove & oil sensing unit ?
pearl111
Baltimore, Maryland
Hi, I have checked out the way to take the governor out of my 6.5 predator engine. Do I need to take the governor arm off that is left hanging inside the engine. And if I take out the oil sensing unit what do I do with the wire that went to the unit.
Poboy kartman
Senior Moments Member
White Settlement Texas
Leave the sensor use the wire for a kill switch or just wrap it in electrical tape so it can't ground out. (As soon as it touches ground...it'll kill the engine.)
Jrgunn5150
Rudderless
Ok thanks do I take the governor arm out that is inside the engine after I take the governor gear out. mike
I did, I had to rotate the engine about a bit to get it down.
Then, i put a 1/4-20 bolt coated in JB Weld in the hole.
pearl111
Baltimore, Maryland
Hello again I am sure this question has been ben asked before I could not find it. I took the governor out of the predator 6.5 I will get the muffler gas jet and air intake up grade do I really need a fly wheel up grade also. thanks . mike.
