Ok so I picked up the bike today, looks way better than I expected. I managed to start it a couple times but it was tricky and as soon as I touched the throttle it would die. I took the carb off and cleaned it pretty well with carb cleaner, although it didnt seem to dirty. The guy I got it from thinks it needs a new needle. What do you guys think could be causing this?
Here are some pictures, I could also use a little help with set up of the carb.
Im not sure where this clear tube should go, I thought it was a overflow thing but there already one on the bottom of the carb.
what does the flat head brass screw on this side adjust?
Thanks in advance for the help guys, cant wait to ride this thing.
