got a tecjmseh h30 no sparks
beansdaddy78
JR. Member
Carbondale IL.
Hey guys wondering if anybody has any info or coukd help me figure out what's wrong. It's a tecumseh h30 3hp. I get no spark, New plug alsk is governer removal basically the same as a clone or a BRIGGS?
Research governor techumesh removal on the forum. Toystory did a writeup that is now a sticky.
No spark can mean many things. Coil is gone, spark plug faulty, spark plug boot faulty, gap between flywheel and coil incorrect, killswitch is grounding on engine etc.....
Look at all those first and take it from there.
Try the kill switch first. The easiest and most common problem
beansdaddy78
JR. Member
Carbondale IL.
thank you for the advice, ill go through the checklist, but honestly i have no idea how to pull a flywheel. im hoping i can afford a gear puller tomorrow but i gotta see what they cost.
You don't need a gear puller for your flywheel. Undo the nut on the flywheel so that the nut just fits over the end of the crank. Now put a piece of wood over the nut (or not if you so like) and whack the nut with a hammer once or twice. The shock should loosen the flywheel and you should be able to get it off. Do not try to pry it off with spanners and screwdrivers. You will just break something.
The reason that you wack the nut and not the end of the crank itself is so that you don't mash up the thread on the crank
Quite possible. Check points, burnish with paper, and check gap setting- should be 0.020".
I converted my H60 to CDI with one of those little retrofit modules- works quite well, and one less maintenance item.
When you go to reinstall the flywheel, be sure to torque the nut to spec- failure to do so will very likely result in a sheared key- another no-start situation. Spec is 37.5 lbs/ft with aluminum nut.
beansdaddy78
JR. Member
Carbondale IL.
Dang now i gotta buy a torque wrench, ill check the local pawn shop for a used one, unless you guys think buying a used one is trouble, please let me know if that would be a bad idea. Thanks for yiur help guys
beansdaddy78
JR. Member
Carbondale IL.
dont mean to sound ignorant, but what does the cdi mean and how would i convert?
beansdaddy78
JR. Member
Carbondale IL.
I took the carb off of this H30 and im not really sure if its cleanable like others (wont break down) all i can do is take off the float bowl and the thing thats under the float by the hinge. the fuel inlet wont even come out and its plastic.
does anybody have any experience with this motor or this type of carb. ill post a pic in a min as long as it works right away, i have probs getting pics from phone to pc
I will wait for the pic.
CDI= Capacitative Discharge Ignition... Electronic ignition, eliminates breaker points and related moving parts.
beansdaddy78
JR. Member
Carbondale IL.
is there any way to get that plastic tube off, the white color one?
im thinking i might try to toss it on a 69 fox minibike i have, its either that one or a tecumseh 2.7 hp 1605a 2 stroke motor. which do you think would be faster ???
beansdaddy78
JR. Member
Carbondale IL.
I finally got the new intake valve in today, lapped it and slapped it in. got a tune up kit for it at RK for $3 which surprised me, put all that in. Got a torque wrench and torqued the bolts to proper specs, and put it all back together but still nothing no resistance when i pull the cord it spins fast. I still got no compression when i once did.
any body got any ideas. i replaced the exhaust valve last week . i think ive tried everything
GoodWComputers
Aspiring Mow-Kart Owner
Oxford, Ohio
I agree, but in order to get my flywheel off I needed to put gentle upwards pressure underneath the flywheel with a large flathead screwdriver. I think as long as you are extremely careful on where you are placing the "lever" under the flywheel, you will be OK.
Best advice I can give - spray the center of the flywheel (underneath/around the nut) with PB Blaster and then walk away for a few hours to let it soak in! That should help a lot.
GoodWComputers
Oxford, Ohio
I believe that you can rent them (very inexpensive too) from Advance Auto Parts. Might even be free rental with a refundable deposit on the torque wrench.
No compression, hmm? If the valvetrain is operating properly and you still lack compression, the rings may well be shot.
I've got an old 3hp- when you pull it, the compression seems nearly non-existent, but sure as poop, she runs. Did you get a spark, yet?
