beansdaddy78
JR. Member
Hey guys wondering if anybody has any info or coukd help me figure out what's wrong. It's a tecumseh h30 3hp. I get no spark, New plug alsk is governer removal basically the same as a clone or a BRIGGS?
thank you for the advice, ill go through the checklist, but honestly i have no idea how to pull a flywheel. im hoping i can afford a gear puller tomorrow but i gotta see what they cost.Research governor techumesh removal on the forum. Toystory did a writeup that is now a sticky.
No spark can mean many things. Coil is gone, spark plug faulty, spark plug boot faulty, gap between flywheel and coil incorrect, killswitch is grounding on engine etc.....
Look at all those first and take it from there.
Try the kill switch first. The easiest and most common problem
Dang now i gotta buy a torque wrench, ill check the local pawn shop for a used one, unless you guys think buying a used one is trouble, please let me know if that would be a bad idea. Thanks for yiur help guysQuite possible. Check points, burnish with paper, and check gap setting- should be 0.020".
I converted my H60 to CDI with one of those little retrofit modules- works quite well, and one less maintenance item.
When you go to reinstall the flywheel, be sure to torque the nut to spec- failure to do so will very likely result in a sheared key- another no-start situation. Spec is 37.5 lbs/ft with aluminum nut.
dont mean to sound ignorant, but what does the cdi mean and how would i convert?Quite possible. Check points, burnish with paper, and check gap setting- should be 0.020".
do you have one of these carbs???You can still clean it. Main jet is accessible from underneath, through that tube.
Do not try to pry it off with spanners and screwdrivers. You will just break something.
I finally got the new intake valve in today, lapped it and slapped it in. got a tune up kit for it at RK for $3 which surprised me, put all that in. Got a torque wrench and torqued the bolts to proper specs, and put it all back together but still nothing no resistance when i pull the cord it spins fast. I still got no compression when i once did.
any body got any ideas. i replaced the exhaust valve last week . i think ive tried everything
