Got a engine job coming up
Fun from Boredom
Alabama Dallas county
Won't know what make or model it is till I see it that's the bummer. Going to check the oil first for metal debri . Anything y'all recomend me check. From what he said it has a motorcycle engine not sure. I will keep you all updated on how it goes.
The, obvious, first thing to check is does it turn over? If it does, great; if not, start pulling it down to find out why; the three most common issues are:
- piston stuck in cylinder
- crankshaft seized to block &
- big end of conrod seized to crank
If it's one of the last two, it's probably an easy fix; if it's the piston, good luck...
