VoodooChild
- Messages
- 39
- Reaction score
- 1
I recently picked up a 6.5 clone during the harbor freight sidewalk sale (wicked deal), and today happened to come across an old man with this torque converter. The price was right so i picked it up. Anyway I'm assuming its a TAV 30 asymmetrical (it has the grooved belt and pulleys on one side) , however i started mocking it up on the engine and i believe I'm supposed to have the 2 inner plates of the pulleys lined up. As i push the drive pulley closer to the engine to meet the driven pulley i run into the mounting plate. I'm guessing I'm supposed to get a spacer, and if i am do you know what size? and will affect the performance because I'll only have like a 1/4" of room to put the outer portion of the drive unit on if i space it to were the inner (straight endges) are lined up. And does the spacer need to have a bevel (chamfer) like the crankshaft and inside of the drive pulley have? Also for the drive pulley isn't there supposed a bronze bushing of some sort on the shaft? Becuase right now its just the plain metal shaft.
And where could i get these parts?
Also can i run the unit toward the back of the engine like it's positioned, or is there a certain direction/angle it needs to be run at.
Finally, this guy also has a number of 1" comet torque converters, which i want to go back and buy off of him to put on a vanguard v twin. How can i tell if its a 30, 40, or 44 series? Do the 40 and 44 series not have the external spring on the driven pully?
Any and all help would be greatly appreciated.
