Goped carb issue.
Jake.B
California-USA
Im stumped on this carb. The engine will fire up and will run 1/4-WOT but will not idle at all. What do you guys think is causing it?
Jake.B
California-USA
Its a 2 stroke 33cc tanaka engine(i think thats
The brand). I made gaskets for exhaust and intake so their are no leaks. It will start up and idle if i warm it up. Once i get past 3/4 throttle it will bog then die. It Also idles too fast the clutch is engaged while idling. It only has idle and fuel/air mixture screws. I cant get it tuned right im not sure what the deal is.
Bluethunder3320
just because you made an intake gasket doesnt mean its all good. while its running spray some starting fluid or carb cleaner all around the gasket and if it runs better than thats your problem.
turn the fuel air mixture out a little and see if it helps
if it bogs and dies when you go full then its probably lean
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
That's true. And I would change the diaphragm within the carb as well as the gasket it sits on. Most likely that's not it, but you want to be 100% sure . Also, the intake mountings on a 2 stroke in particular are fussy. If theres an air leak, it's going to throw it off.
