although an automotive map sensor is only measuring manifold pressure
it shouldn't change much if at all
just atom presure or if turboed then boost pressure
even a turbo car will run with out a map (sorta)
but runs **** with out a maf
unless u put it post throttle plate and measure vacuum
who knows
maybe i just dont under stand your explanation
ill stick to the diesels
no sensors needed there
Well forget ANYTHING about automotive injection systems, they all (even ancient ones) make calculations based on the values send by sensors.
With this one that's not the case!
The sensors are basically all just there to controll the timer which then triggers the injector.
A MAF only sends a voltage (waveform) back to the ECU,
that calculates the amount of fuel to be injected based on said voltage. (mixed lookup table and correction values based on other sensors)
Again, this EFI cannot do that at all.
A MAP will send the exact same waveform to the EFI board,
less accurate -yes-; but still useable.
And since the board mainly consists of trimpots
those will blur out any additional accuracy anyways.
that's why -if you ask me- a MAF would be overkill for this scenario (analog efi) a MAP is more than sufficient.
get rid of the idea that you need any serious pressure to recognize a difference in the MAP signal.
if the sensor is placed inside the throttle body the output will vary based on the air flow inside the throttle body.
(I'm not sure about the connecting hose and the onboard sensor... but it should too, maybe just inversed)
