Good plans for a racing type frame?
roflitskyle
Hi all,
I am new to this go karting, and I really want to build a racing style frame. I just don't know where to get them. If any of you could point me in the correct direction, it would be greatly appreciated.
Thank you.
I've had a chance to briefly look over the plans you linked to me. I think that they will suffice, modified slightly to suit your needs. The only real PITA I see so far is that the dimensions are all in Metric. Being Canadian, I am familiar with the metric system. Doesn't mean I work in it, though!
FTR, mm/25.4=inches
To give you an example, look at the front spindles (stub axle)- you'll see a shoulder in the middle of it, and a stepped down area at the end. This can be simplified- the shoulder is replaceable with a commonly available lock collar. The stepped portion at the end can remain straight. At that point, the wheel can still be retained by several good methods.
roflitskyle
FTR, mm/25.4=inches
Thank you, if I can't find anything else, I will probably just go with these plans.
If any one is wonder what the plans are, here they are: http://www.kartbuilding.net/racingk...F/Main_Kart_Complete_01_Complete_Assembly.pdf
