gonna convert a Briggs from V to H
supermanotorious
Winchmaster 5000
New River, AZ
this here is the motor from a mower I bought on Craigslist several years ago which ran for a long time and died before I got all smart on engine repair
the other day I thought, why not revive it, then I came across this corny but helpful video and decided to convert it from vertical to horizontal shaft
I will use it to power a mini bike I will fabricate from scratch, including a custom engine plate to mount the engine!
http://www.youtube.com/watch?v=mFnZkldAwy8
dragos28
Trouble Maker
Bakersfield, CA
thats pretty cool..
i've seen some really cheap riding lawn mowers on CL with 12hp engines that were going for like $100...
i'm not sure if it would be worth the hassle with a 4hp... but either way it would be a cool project.
B.M.800
TheBeal.
Central PA
thats pretty cool..
Ive thought about doing this. Would be pretty cool to do it with some big ole twin cyl.
rocketkart
florida
I like to take riding mower's trans and turn it on it's side and bolt it up to some gokart's and use the 212cc H/F engine's on them so i got reverse and a low gear. small pully on the trans and a big pully on the engine & a idler pulley to ingage the belt. thay work awsome.
54inches
Vagitarian
Houston, TEXAS
I like that!
ML-TOYS
long island, new york
Post some pics of this cause When you flip it isnt the output shafts now verticle ?
with a transaxle
Not necessarily, just turn it having the axle fixed.
(or the output shaft for that matter on a smaller gear box)
Uhh yeah , Im pretty sure that puts the shafts the wrong way..........
if you turn the engine now 90° so that it the flywheel is facing the back and the clutch is facing the front of the kart...
that might work.
It might be complicated to keep the gears lubricated or even shift properly.
And I don't say it's doable, or even practical
but I don't think it's impossible either ;)
I've never seen a carb that uses the gas tank for the bowl, that is going to be a challenge for rotating the carb
As mentioned, B&S used that design for decades; the carb has an internal pump to pull the gas into the carb...
Difficulty in rotating it depends on how it's mounted; over here, the carb sits on a round tube & is attached with bolts on the tank, not the carb. If that's the case with yours, rotating it should be simple enough.
However, if the carb bolts on, it may be a bit more difficult...
Well I would THINK (reads: I don't know for sure)
that the intake header (manifold) of the existing carb
cannot be used for the upright mounting position;
therefor you'd need a new one.
That is if the manifold isn't part of the carb, otherwise you'd need a new carb of course :(
[EDIT]
Thanks Tony.. that would indeed be an easy thing to do;
supermanotorious, how about some images of the carb and stuff.. ?
