GoKart Senior Project Advice
Jacka$$withawrench
Georgia, USA
CO2 is about half the cost of argon. If you are only welding mild steel, CO2 will work. Welding stainless steel or aluminum would require argon, but with a simple MIG welder, a small 20 pound tank of CO2 would be fine. The tank can be purchased for about $125 here locally, and about 30 bucks to fill it.
could you use a propane tank? and could you fill a bowl with CO2, then weld down in it to avoid having to flow gas?
Sparkwizard
Richlands ,NC USA
Oh, damn...Not sure about the bowl idea...but nobody will fill a propane tank with CO2 for you.
What about welding inside a sand blast cabinet with a fire extinguisher connected? The CO2 wouldn't blow away in there.
kitzimoose
ok thanks, I'm definitely going to look around and see if i can get a used tank and maybe a whole setup used
