Gokart MZ 250
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
not much lately...
new design of gear shift lever, now I can have natural first down and up-up-up shifting...
added two additional support bars from sides...
also with top sophisticated tool available on market, cut tooth on sprocket..
pics below ...
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
huh, it's been a while ...
* managed to make new kick starter (on one picture I marked parts with different colors , as it is not very clear )
* brakes are completely finished, caliper in place, disc locked on axle, pump screwed to chassis, cable connecting pedal and pump adjusted.
* what is left? axle sprocket has to be fixed on axle (hub needed :p) .. also I was planning to make new spindles and will add bearing on spindle bolts (if you know what I am trying to say).. still not decided wich clutch lever going to use ..
anyway, few pics and video ..
https://www.youtube.com/watch?v=SRJl8H61AZ4
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
Hi ..
not much progress .. only new spindles and "spindle carrier" ?
added flange bearings in it ..
some new parts arrived like air filter, cables, exhaust ..
also found used rev-counter .. need to order cable for it ...
I ordered gears for it , but forgot to order cable ..
