gokart identification
mr.build_it_all
ohio
Can anyone tell me what kind of go kart this is.been trying to figure it out for months closest i could find was a manco dingo 285, but this kart it different and built way stronger.thanks in advance will add better pics of just the frame when i can
mr.build_it_all
ohio
Thank you.i have searched for months and i couldn't find any marking on it anywhere.do you have anymore info about them and i need the huge tires at the place i ride.
You can run whatever tyres you want, as long as you compensate for that with your gear ratio ;)
I just mentioned that so that in case everything else is original, you're not wondering why it burns clutches/belts like crazy ;)
Sorry, not much info at all..
IIRC it came originally with a 5hp briggs and a series 30 TC, but IDK much which ratio it had originally..
I see your Torqueconverter has been replaced with a std belt pulleys which of course is removing all the benefit of having a TC and rendering your ratio nearly useless I'd assume.
Again, if I'm not mistaking it had 20" tyres on the rear and large diameter but narrow fronts (more like kid-bicycle wheels but sturdier of course) as well as a bicycle-style handle bar instead of a steering wheel.
I've seen a few around the forums and a sibling or two (slightly different Bird chassis)
Sorry, apart from that not much I can tell you about it.
[EDIT]
this is about as original as it gets (uhm bad shape but still ;)):
mr.build_it_all
ohio
Thanks for the info i picked this up as only the frame for 40 and just threw a bunch of parts i had onto it but i got the tc coming in the mail.as for gearing im running 10/66 and probably dropping to 18 inch rear tires.
mr.build_it_all
ohio
Would i burn up a tav2 if i keep the 22 inch tire on really rough terrain.im talking steep hills and deep mud
