Go_kart project
M@ster
Hey people! I am building the go-kart and I'm puzzled what the rear suspension will be look like.
What I have right now:
Main frame is from ironing board base. It's amazing what you can use in go-kart construction.
Please, some ideas will do no harm! Thanx.
TOO FAST
Canada
Hey you could iron while driving! Seriously what kind of suspension are you thinking about. A swing arm pivoting off the
jackshaft would be simple with a coil over shock.
theo
I think the od is to small. One way to see how much sag you will get is to put a chair under each end as close as you can get to the end, and then put a piece of plywood on it and then sit on the plywood.
theo
TOO FAST
Canada
Here's a drawing of the swingarm principle. Hope is helps.
The back axle pivots on the same shaft as the final drive chain.
Does require more bearings, and construction
Tommy Boy
Idiot
Amidst the sand fleas west of Tulsa
Or to simplify it and save the issue of setting up a jackshaft, you can mount the motor and axle to its own section of frame which then hinges on its attachment point at the front frame section. Like a door hinge, but instead of being the entire width of the frame, having mount points on the frame for your "hinges".
The easiest way I found is to make C brackets (like you would with a spindle) out of flat stock which you then drill to carry the size of bolt you prefer. Cut bushings from black pipe that will accommodate the bolt size to lengths that will fit snugly within the C brackets. Grind the brackets so the outside diameter of the bushings will extend slightly beyond the brackets or better yet, cut appropriately sized pieces of square tube to the length of your bushings, then cut off one side to make another bushing-sized C bracket. Weld these to your bushings to to serve as risers to lift the main C brackets away from the lower frame/engine side. Weld the C brackets to the upper/front frame and bolt 'er up.
All you have to do at that point is build a rail or tower on the front frame to mount your upper shock(s) mount to and set up a shock mount on the rear frame. Mount your engine and live axle to the rear frame section and bingo.
You're straight live axle, no jackshaft, no CV joints, AND you have rear suspension with a little steel, a welder, and some hardware.
M@ster
Thank u Tommy Boy and TOO FAST, but I trend to leaf springs. It's cheaper and easier to make. Here is the pic of my idea:
What do you think?
brendonv
Australia, Perth
Wouldnt that be a lot of stress where the leaf spring connects to the frame? Better make sure those welds are perfecto. Also ur gonna have to have more supports going across the frame, or it will just bow.
TOO FAST
Canada
Problem with leaf springs is one side of your wheel can go over a bump causing the axle to be crooked - no big deal but how do you
keep your chain from jumping off? You might need a linkage to
keep everything aligned
mike75925
thinker and tinkerer
Alto, tx
you can do a swingarm or leaf spring without mounting the engine attached to the assembly but you would need tensioners and maybe guides if your chain is too long
M@ster
