fowler
dad and i went to clean up around one of his houses so they can rent it out
took his lawn mower
but when cleaning out the shed i found this victa
dad has no memory of it
and can only assume it belongs to the previous home owner
who sold the joint to us 8 years ago
anyhow put fuel in it and it started 2nd pull
deciided to use it to mow the 30* hill out the front as to not starve the good newer mower of oil
noticed it was cutting in and out over bumps
further investigation found the spark plug lead off
im not sure how it is staying running
i can only assume it either has that much punch from the coil that its jumping from the lead thought the old rubber boot to the plug then still having enough to light the mix
or its running that rich (about 2lt in 1 hour)
and that hot that its just compression igniting
http://www.youtube.com/watch?v=ki0Yq4r_ZPA&feature=youtu.be
took his lawn mower
