At the centre of the clutch ?Check for set screws. Or bolt in center.
It looks like there is a good bit around the cover over the flywheel and mag. Would be a good idea to clean that off too. No airflow means no cooling.While you're messing with it, take that sheet metal loose from around the cylinder and clean that pine straw and stuff out of it. It's not meant to be a heat shield or guard, it's to funnel airflow from the cooling fan to pass around and through the cooling fins of the cylinder. Stopping up or reducing that cooling air is something you'd regret when it gets to be hot weather again.
