GoKartNarc
Maintained Machine
I have a 420cc predator engine on a Manco Dingo frame. It has a torque converter on it and disc brakes. The engine only has about 2hrs on it. I rode it several times before, but I had to make the engine higher and make a few adjustments to the torque converter spacing. When I work on it I take the two 22"x7" rear tires off and put the Kart up on stands. Recently I finished working on it and it started right up and it runs great with the rear tire's off. Then I put the tires back on and lower it to the ground and try to start it, but it won't. I've adjusted the idle, but it still won't start. Am I not adjusting the idle high enough? I'm concerned if I adjust it too much its going to start up and take off on me.
Any suggestions??
Thanx
Any suggestions??
Thanx
