go kart wont idle
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Ok so I have a GX200 which ran great a few months ago and now its having some issues. I cleaned the carb like a month ago in lemon juice and sealed it on nicely with gasket sealer all around the intake and torqued it on. The engine cranks up on its first pull, but it'll die if it isn't given gas. I turned the idle screw up and it'll idle high, but it'll die. Howeverrr I know its not dirty because you can pull all the way back on the throttle lever and it'll run perfectly fine at 4000 RPM. Then when you move the lever back to the orifinal position, it dies. Is there an idle jet that I need to clean?
r_chez_08
Should be in the shop...
Cornwall, UK
look around the butterfly, I think the idle jet is under your black idle screw. The idle jet is made from black plastic and pops up with a flat head screw driver.
Hope that sorts your problem,
colinm
Northeastern Ohio
...sealed it on nicely with gasket sealer all around the intake and torqued it on...
Just a thought...
If by "gasket sealer" you mean something like RTV gasket sealer, like you might use on a differential cover, you may want to read the packaging. I don't think that it is supposed to be in contact with gasoline. Maybe it's got a leak in it?
