Brandon1023
needs an oil change
Ok so I have a GX200 which ran great a few months ago and now its having some issues. I cleaned the carb like a month ago in lemon juice and sealed it on nicely with gasket sealer all around the intake and torqued it on. The engine cranks up on its first pull, but it'll die if it isn't given gas. I turned the idle screw up and it'll idle high, but it'll die. Howeverrr I know its not dirty because you can pull all the way back on the throttle lever and it'll run perfectly fine at 4000 RPM. Then when you move the lever back to the orifinal position, it dies. Is there an idle jet that I need to clean?
