Go Kart Wheels
rpolanco
West Sacramento, CA
Where can I find some wheels identical to these? These are identical to the ones I broke into 5 pieces, and I haven't had any good luck finding them anywhere online that has them in stock. They came off of a Tyrod 4 go kart
I understand these are made of unobtainium, that rare metal...
I think Azusa Tri-Star wheels are going to be your best bet and a fairly close match.
If anything, the Tri-Stars are going to be 10x more rugged.
rpolanco
West Sacramento, CA
I've looked into these before, the problem with these is that they are on a 3.75 (3 3/4) bolt circle pattern, and my hub and wheel are on a 3 3/8 bolt circle pattern
950speed
Texas
What do you mean? I do not see any “bolt pattern” in the picture only bearings, if that’s the case just pop in new bearings
And if you do mean the rear tires, I have not found anything for the pattern described, but you can simply get new hubs, because I would think there is. A 99% chance the rear axle is a 1 inch just order new wheels and matching hubs, because if you need t again later on and you can’t find any now, imagine the price
Shep1970
Massachusetts
This little guy has been in my shed in the back corner for about 10yrs it’s got maybe 5hrs use on it.(son out grew it) These look like the rim/tire your looking for so find this bike online and you’ll find what your looking for. Cheap 49cc kids quad made in China.
I also wanted to upload pics so I didn’t forget how to.:yawn:
I think this is them/ unless of coarse I’m wrong. https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/281275675540
Shep
those are available in chinese shops sometimes
(gearbest bangood aliexpress and alike)
[best bet would be aliexpress..]
and they sometimes show up on ebay as well
Other than that you will have not much luck finding them
Konnor, the halfs are bolted together and they use the same bolts to fix the hub for sprocket and/or brake disc on the rear wheels.
