In order of awesomeness:
miller, lincoln, hobart, everlast(Chinese) and the 'other' Chinese junk (some Chinese products are better than others)
A lot of the lower end ones called "flux core" welders would do a good job maybe up to 90 amps tops, 110v only.
If your friend wants a better welder, he could get a lincoln or miller, a lot of them go up to 110-140 amps with is generally plenty for go karts, and could switch up to higher amps if you had a 220v outlet (they do 220 and 110 depending on model)
If you want higher quality welds, you are going to have to get a 75/25 mix of argon and co2 and do the gas mig welding (sorry not correct terms). You can do that kind of welding on some of the lower end welders, but then you start getting into the more expensive territory with the tank and higher end welders.
Any welder that plugs into a 220v outlet will definitely do the trick, and be useful for most other applications.
Here are a few miller/lincoln models to look at, just use their max amps (and possibly some unit conversions to metric) as a baseline to compare against other welders:
http://www.millerwelds.com/products/mig/onephase.php
http://www.lincolnelectric.com/en-us/equipment/mig-Welders/Pages/mig-welders.aspx
http://www.everlastgenerators.com/Mig.php
