Go Kart USA TC chain issue
vert
I have read several threads on the forum that helped me and my son build his kart. The kart is a go kart usa kit with pred. 212cc motor and we are trying to place reproduction TAV2 TC on it. I mounted the motor 1" in order for the plate to clear the rear frame rail, but now once I place the chain on, the chain rubs the frame rail as it comes off of the sprocket on the TC.
The plate has various mounting holes, but either the fins from the head hits the plate or the ribs from the TC plate hits the motor so no other holes will line up. I thought about elongating the current holes to move the plate forward or trying to find a chain guide to place on the rail.
Im open to suggestions and I plan on calling go power today to see what they have to say.
Thanks
we need some pics to say what's possible and what not.
what you mustn't do however is elongating the boltholes of the backplate... the distance between driven and driver mustn't be changed, that'S why there are holes, not slots ;)
Now the motor mounting plate however should be slotted, since that will ease adjusting the chain tension.
Again we need pics
vert
Again we need pics
That's is true I didn't think of that. I was thinking it would be ok since the whole assemble would move, but then my belt wouldn't work. I get some pics after work.
vert
Here you go
KartFab
Dallas, TX
I would elongate the holes and buy a half link just in case i need to fine tune the chain.
vert
I assume you're meaning the motor mounting holes since I was wrong on elongating the mounting plate holes.
So I am either going to cut the gas tank mounts off and fab up new brackets for to so I can move the engine forward .5".
Or I am going to see if I can trim the ribs on the back of the plate in order to move the TC forward one hole.
The only response I got out of go power was that they are not made to fit all karts, but surely someone else has tried this before on a go kart usa frame.
KartFab
Dallas, TX
Ummm I dont know what you mean. there is an engine that has holes for mounting, those should not be cut or elongated.
Then there are holes in the steel plate that the engine mounts to, these can be cut.
So the torque converter has a fixed distance between the drive and driven unit. Moving the backplate to modify this distance will create problems.
Now this may look a little funny, but remember that the torque converter backplate can be rotated for all sorts of positions around the motor shaft, you are only looking at one position.
Another idea is if you really have to resort to moving the gas tank, you can always mount it somehwere else (even lower) and install a fuel pump (clone and gx200 type engines use this set up with the fuel pump)
